Hi!
I have a problem with playing wmv(WMV3) video. Any of players, I've tried (VLC, KMPlayer, Windows Media Player, Media Player Classic), play only video but no sound, sometimes at all, sometime just a few minutes. Here the information about this video file from KMPlayer:
Also I've tried play this file in different OS, Ubuntu with Medibuntu package and w32codec package installed and in Windows with the latest K-Lite Codec Pack, but these actions had no effect.Code:General Complete name : Introduction-1.wmv Format : Windows Media File size : 370 MiB Duration : 31mn 17s Overall bit rate mode : Variable Overall bit rate : 1 654 Kbps Maximum Overall bit rate : 9 564 Kbps Encoded date : UTC 2008-06-05 13:38:39.768 Video #2 ID : 2 Format : VC-1 Format profile : MP@HL Codec ID : WMV3 Codec ID/Info : Windows Media Video 9 Codec ID/Hint : WMV3 Description of the codec : Windows Media Video 9 - Professional Duration : 31mn 17s Bit rate mode : Variable Bit rate : 5 000 Kbps Width : 1 680 pixels Height : 1 050 pixels Display aspect ratio : 1.600 Frame rate : 15.000 fps Nominal frame rate : 29.970 fps Resolution : 24 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.189 Stream size : 1.09 GiB Language : English (US) Audio #1 ID : 1 Format : WMA3 Format profile : M1 Codec ID : 162 Codec ID/Info : Windows Media Audio 3 Description of the codec : Windows Media Audio 10 Professional - 384 kbps, 48 kHz, 2 channel 24 bit 2-pass VBR Duration : 31mn 17s Bit rate mode : Variable Bit rate : 305 Kbps Channel(s) : 2 channels Sampling rate : 48.0 KHz Resolution : 24 bits Stream size : 68.4 MiB (18%) Language : English (US)
Any comments and recommendations how can I play such file are greatly appreciated...
You could try reconvert the audio to wma2, see https://forum.videohelp.com/threads/310333-How-to-change-audio-codec-in-WMV-video-from-...=1#post1914340
And I guess you have tried play with latest wmp 12? -
No, I've tried with previous version of WMP. I'll try to play it in the newest version.
Does Windows Media Encoder support batch encoding or command line options?.. -
By the way, since I'm using Microsoft Windows XP SP3, WMP 12 is not the best for me, Microsoft says
Windows Media Encoder was unable to convert my file, saying that "The given unit is corrupted, badly formatted, or otherwise not valid"... I'm stucked...
In any cases, converting is very time consuming process for me...
Is there any other way to play this kind of file?..Last edited by sapfeer; 16th Mar 2010 at 08:25.
Video encoded with VC-1 WMV3 problems
By namenone in forum Newbie / General discussionsReplies: 8Last Post: 16th Feb 2012, 18:15 -
Virtualdub and AVC file (decoding problem)
By EdoScario90 in forum Video ConversionReplies: 4Last Post: 12th Dec 2010, 11:33 -
Faulty wmv3 (9) codec problem
By Darius_bd in forum Newbie / General discussionsReplies: 6Last Post: 26th Dec 2008, 17:30 -
decoding audio for mkv using m2ts file PIDS error dg index used
By davidc78au in forum DVD RippingReplies: 1Last Post: 9th Feb 2008, 22:28
