have a divx player and want to create chapters know how to do it with iso trying to save space to get multiple movies on 1 dvd and assume chapters would transfer as well.
If you are saying you have a dvdiso with multiple episode of such as a tv series, try opening the iso using fairusewizard.
looking to turn a iso file into a avi file. I currently have a iso file with chapters that I want to be able to use not just one constant avi file. with chapters it makes it easier when searching for an exact spot.
I believe chapters in a Divx file depends solely on the player. You can add them
to your file but there is no guarantee they will play correctly. The player must say
"DivX blah blah blah Certified" or something along those lines.
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 19:13 -
Convert to .ISO
By Jomapil in forum ComputerReplies: 3Last Post: 2nd May 2009, 19:02 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
Help convert avi to iso
By thasco in forum MacReplies: 4Last Post: 12th Nov 2007, 19:33
