    Jan 2004
    Hi,
    I recently had a hard drive failure--had to reformat etc... Am a longtime subscriber to the above...the old school version..where you paid once for life...I'm not ready to jump to Blu-Ray yet...
    Looking at Slysoft website it looks like they are not just going to email it to me... Is this true?
    I backed up programs etc. 6 months or so ago to an external HD...is it on there somewhere and how do I find it?
    anybody been to this party?
    Thanks,
    bhb
    Oct 2005
    666th portal
    the license file is a text file in the slysoft folder that starts with key.XXXXXX probably in your email also from when they sent it to you. you have a backup of the email database, right? if all else fails go to their support section fill out the email form and beg. they might send you a new key.
  3. Here on Video Help, if you visit too section probably you will find tons of FRee tools which performs far better than paid tools which need license or a key or serial number.
    I guess i have saw a similar tool like DVDClone on Mr.Bass.org website DVD2DVD or something like that.
    personally i use DVDDecryptor + DVD43 + DVDShrink + ImgBurn (I LOVE THAT)
  4. DVD Ninja budz's Avatar
    Jan 2003
    In the shadows.....
    ^^^Those programs are not able to bypass the newer copy encryption on newer dvd movies.
  5. If bhbuckeye purchased the license back before the switch to the different licensing options then the license has been grandfathered and will remain valid for the lifetime of the program development. There is still a lifetime option anyway. There is no begging required to get a replacement for a lost license keys as long as a valid license was previously purchased. The same holds true for CloneDVD. It always helps to understand how things work. Take a look at the official Slysoft forums and you'll see people lose their keys all the time and get them replaced.
    Here's the Slysoft contact page: http://www.slysoft.com/en/contact.html
    Visit that page and use the "Lost license key" option from the drop-down menu to request the replacement keys. If for some reason there is a problem then use the drop-down menu and select "Common enquiry" and request help obtaining a replacement key.
  6. Member ricoman's Avatar
    Jun 2004
    CT, USA
    No problem, my HD crashed a year ago and I just emailed slysoft and Elby (that's how old my license is). They had it on record and sent me the key.
    I love children, girl children... about 16-40
    W.C. Fields
