Results 1 to 11 of 11
  1. Can someone help me figure out why some of my dl'd m2ts bdrips fail with the wavi+aften... I'm a newb and all my settings are default except ntsc and I use hcenc 1 pass for most things... I don't know if this is a specific problem w/ my settings or if its isolated to this dl'd rip. Here is the log:
    <3/15/2010 7:56:21 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Video Standard: NTSC
    DVD Titles number: 1
    DVD Size: 4450/4450 MB (100%)
    DVD Output Setup: DVD Folder
    DVD Label: DVD
    DVD Menu: No Menu
    Output Folder: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer
    Delete Temp Process Files: Yes
    Delete Working Files: Yes
    Edit Command Parameters: No
    Post Process Task: Show Progress Status window
    PREFERENCES
    AVS Source Filter: A2DSource
    AVS Resize Filter: Lanczos4Resize
    Video Resolution: 0
    Video BitRate Min: 2500
    Video BitRate Level 1: 6000
    Video Profile Level 2: 4500
    Video BitRate Max: 8500
    Keep DVD Compliant Video: 1
    AC3 Audio Encoder: 0
    DVD Audio Format: 0
    DVD Audio BitRate: 192
    Keep DVD Compliat Audio: 1
    Normalize Audio: 0
    DVD Audio Language: EN - English
    DVD Subs Language: EN - English
    Chapthers Interval: 5
    Use Source Chapters: 1
    DVD Burning Drive: D: HP DVD Writer 1270d GH24
    DVD Burning Speed: 4x
    Auto Erase DVD RW: 1
    Save Log file: 1
    Unload ActiveMovie library: 0
    Adjust ffdshow mixer: 1
    TITLE 1 SOURCE FILES
    Video: C:\Documents and Settings\vicsedition\My Documents\My Videos\CodecFiles\Cutthroat Island\Cutthroat Island.m2ts
    Info: AVC - 3762 kbps - 1920x1080 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:04:32 hours - 179154 frames
    Audio: C:\Documents and Settings\vicsedition\My Documents\My Videos\CodecFiles\Cutthroat Island\Cutthroat Island.m2ts
    Info: AC3 - 640 kbps - CBR - 48000Hz - 6ch - 2:04:32 hours
    Subs:
    [MediaInfoLib - v0.7.26]
    AVISYNTH SCRIPT
    Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
    Video = A2DVideoSource("C:\Documents and Settings\vicsedition\My Documents\My Videos\CodecFiles\Cutthroat Island\Cutthroat Island.m2ts", CacheFolder = "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp")
    Audio = A2DAudioSource("C:\Documents and Settings\vicsedition\My Documents\My Videos\CodecFiles\Cutthroat Island\Cutthroat Island.m2ts", CacheFolder = "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp")
    Video = Video.ConvertToYV12
    #Using DGPulldown to upsize FPS
    Video = Video.Lanczos4Resize(720,480)
    AudioDub(Video, Audio)
    START VIDEO ENCODING OPERATIONS
    Encoding Profile: HCenc VBR 2-pass
    Target Video FileSize: 3936.1 MB
    HCenc Parameters: -ini "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island.avs
    *AVSRELOAD
    *OUTFILE C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v
    *LOGFILE C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 4419
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *BIAS 40
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 0
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <3/15/2010 12:11:54 PM>
    END VIDEO ENCODING OPERATIONS
    A2DVideoSource: DirectShowSource
    Created File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v (3937.7 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4455 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:04:24 hours - 178977 frames
    START PULLDOWN OPERATIONS
    DGPulldown Parameters: "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
    <3/15/2010 12:16:33 PM>
    END PULLDOWN OPERATIONS
    DGPulldown executed on File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v (3937.7 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4450 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:04:32 hours - 179154 frames
    START AUDIO ENCODING OPERATIONS
    Wavi+Aften Parameters: "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.ac3"
    <3/15/2010 1:57:50 PM>
    Problems encountered during Title 1 AUDIO encoding operations.
    START (BACKUP) AUDIO ENCODING OPERATIONS
    FFmpeg Parameters: -i "C:\Documents and Settings\vicsedition\My Documents\My Videos\CodecFiles\Cutthroat Island\Cutthroat Island.m2ts" -y -vn -ar 48000 -ab 448k "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.ac3"
    <3/15/2010 1:57:54 PM>
    END AUDIO ENCODING OPERATIONS
    A2DAudioSource: DirectShowSource
    Created File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.ac3 (4.7 MB)
    <3/15/2010 1:57:57 PM>
    PROCESS ABORTED DURING TITLE 1 AUDIO ENCODING OPERATIONS.
    CHECK LOG FILE <C:\DOCUMENTS AND SETTINGS\VICSEDITION\MY DOCUMENTS\CONVERT_XFER\DVD_0.LOG> FOR MORE INFO.
    Log file created by AVStoDVD Release 2.2.6
    As a side note I have read some online guides for Bdconverts with a2d and followed the instructions to a tee and it wouldn't even pass its channel search or whatever. I changed the settings to hcenc 2 pass and quenc audio and then changed to ntsc... thats all they said to do and it wouldn't do a thing. Please help! I love reading guides but alot of them are just "do this and that" without explanations of things... like is this possibly a bitrate issue? Here is the mediainfo for the input file...
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 4.00 GiB
    Duration : 2h 4mn
    Overall bit rate : 4 594 Kbps
    Maximum Overall bit rate : 35.5 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 3 frames
    Duration : 2h 4mn
    Bit rate : 3 763 Kbps
    Nominal bit rate : 3 661 Kbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 23.976 fps
    Resolution : 8 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.076
    Stream size : 3.27 GiB (82%)
    Writing library : x264 core 80 r1376kGIT 3feaec2
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=2 / keyint=240 / keyint_min=24 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3661 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=25000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.00
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Duration : 2h 4mn
    Bit rate mode : Constant
    Bit rate : 640 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Surround: L R, LFE
    Sampling rate : 48.0 KHz
    Stream size : 570 MiB (14%)
    Language : English
    all I can figure is that wavi+aften has size requirements and the above stream size might be too large? for the wav format? I'm a newb so gimme a break.. Maybe I should switch to ffmeg+aften for audio coding? This could end up fixing my only consistent problem with this program... any answers are really appreciated.
  2. I retested the above m2ts and to my surprise even with errors plays audio just fine... I have fed it into mediainfo and it seems to have 6channel and everything. Wavi+aften failed because of the file size and then ffmpeg backup started. During the end of this I received this error : allocation of read buffer. (? don't know what it means) and then at the very end it said that my duration was 0:00 and that it was less than the the input file... which is ALL very weird considering that when done VLC plays the movie fine with no sync problems or anything... this happened to the m2ts file I just did previously also... minus the duration and buffer errors... just the wavi+aften and then ffmpeg was succesful... can anyone help me out with these questions? Would truly appreciate it. This is driving me nuts... heres the new log but I don't see anything about the buffer or the duration included... strange..
    <3/16/2010 6:32:21 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: DVD
    DVD Menu: No Menu
    PREFERENCES
    Video Resolution: 0
    Video BitRate Level 1: 2500
    Video Profile Level 2: 2500
    DVD Audio Format: 0
    Normalize Audio: 0
    Save Log file: 1
    Subs:
    AVISYNTH SCRIPT
    Encoding Profile: QuEnc CBR 1-pass
    QuEnc Parameters: -i "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island.avs" -o "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v" -b 4419 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 9 -priority 5 -auto -close
    <3/16/2010 8:56:03 PM>
    Created File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v (3936.2 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4419 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive - 2:04:24 hours - 178977 frames
    <3/16/2010 9:00:48 PM>
    DGPulldown executed on File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v (3936.2 MB)
    OUTPUT VIDEO INFO: MPEG-2 Video - 4419 kbps - 720x480 - DAR 1.778 - 23.976 fps (CFR) - Progressive (2:3 Pulldown) - 2:04:32 hours - 179153 frames
    <3/16/2010 9:15:37 PM>
    <3/16/2010 9:20:44 PM>
    Created File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.ac3 (399.1 MB)
    <3/16/2010 9:20:58 PM>
    START DVD AUTHORING OPERATIONS
    BatchMux Parameters: -arglist "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_BatchMux.ini"
    BatchMux ini file:
    -d "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0\VIDEO_TS"
    -mxp "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_MuxMan.mxp"
    -l "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_MuxMan.log"
    -muxman "C:\Program Files\AVStoDVD\MuxMan"
    -prio LOW
    -v "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.m2v"
    -vidmode LB
    -a1 "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0_Cutthroat Island.ac3"
    -a1lang en
    -cellfr "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island_MuxMan.txt"
    -progfr "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island_MuxMan.txt"
    -chapfr "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_0_Cutthroat Island_MuxMan.txt"
    <3/16/2010 9:30:28 PM>
    END DVD AUTHORING OPERATIONS
    Created Folder: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_0 (4429.9 MB)
    <3/16/2010 9:30:29 PM>
    THANKS
  3. Originally Posted by VicSedition View Post
    Your assumptions are correct (too large wav intermediate file, Aften cannot handle it properly). Switch to QuEnc and retry. Let us know your progresses.
    Bye
    MrC
    AVStoDVD Homepage
  4. I tried setting just the audio encoder to quenc and then got immediate errors where arguments are usually passed... So I will try to use Quenc 1 pass setting and leave the audio encoder as is with ac3 wavi aften which I'm sure just transfers to another if it fails? right? The weird thing that I don't understand is that the file (for all its errors) still plays fine and seems ok as far as playing on my computer... I haven't burnt it yet so I'm not sure if there will be issues there but I'll continue to chase down these avenues of error until I know a little something... I'm currently converting and will report my findings... as always thank you for your response!
  5. So I have retested again with quenc (locking the bitrate to ensure it starts in quenc) all other options are default.. upon audio encoding received another error and the program aborted itself... however ffmpeg in the log states that ac3 was produced... I did not force an abort it just hung forever and THEN I had to abort manually.. so what I have left are the m2v and ac3 files...here is the new log:
    <3/17/2010 4:35:23 PM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: DVD
    DVD Menu: No Menu
    PREFERENCES
    Video Resolution: 0
    DVD Audio Format: 0
    Normalize Audio: 0
    Save Log file: 1
    Subs:
    AVISYNTH SCRIPT
    QuEnc Parameters: -i "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_1_Cutthroat Island.avs" -o "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_1_Cutthroat Island.m2v" -b 4419 -1 -hq -novbr -scene -trell -aspectratio 16:9 -nointerlaced -mpeg2mux noaudio -dc 9 -priority 5 -auto -close
    <3/17/2010 7:00:11 PM>
    Created File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_1_Cutthroat Island.m2v (3936.2 MB)
    DGPulldown Parameters: "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_1_Cutthroat Island.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
    <3/17/2010 7:04:38 PM>
    DGPulldown executed on File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_1_Cutthroat Island.m2v (3936.2 MB)
    Wavi+Aften Parameters: "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_1_Cutthroat Island.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 -pad 0 -dynrng 5 -bwfilter 0 - "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_1_Cutthroat Island.ac3"
    <3/17/2010 7:45:02 PM>
    FFmpeg Parameters: -i "C:\Documents and Settings\vicsedition\My Documents\My Videos\CodecFiles\Cutthroat Island\Cutthroat Island.m2ts" -y -vn -ar 48000 -ab 448k "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_1_Cutthroat Island.ac3"
    <3/17/2010 7:45:07 PM>
    Created File: C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_1_Cutthroat Island.ac3 (5.9 MB)
    <3/17/2010 7:45:10 PM>
    CHECK LOG FILE <C:\DOCUMENTS AND SETTINGS\VICSEDITION\MY DOCUMENTS\CONVERT_XFER\DVD_1.LOG> FOR MORE INFO.
    Is there a possibility that the original file is problematic? I have encountered this with more than one m2ts... as stated before most input values seem the same to me however some pass and some fail... should I select the Quenc program and ALSO specify Quenc as the audio decoder?
  6. Originally Posted by VicSedition View Post
    When exactly did you get errors? Video section, audio section, whatever?
    You have only to select QuEnc as AC3 audio encoder, NOT as video encoder.
    Bye
    MrC
    AVStoDVD Homepage
  7. ok to clear up some confusion... the problems occur after the audio encoding starts... all video encoding seems to be fine.. as the input file is ac3 I've rarely had problems converting my m2ts files.. however about 20% have errors surrounding the audio encoding portion... mostly after wavi+aften fails....
    I just set all preferences to default, then I changed my directories, ntsc, and selected and set as default the Quenc audio selection... leaving everything else alone... I get an error immediately at this point during the video process (title 1 standard error which is different because all previous errors are within audio) here is that log:
    <3/18/2010 1:39:12 AM>
    START PROCESS
    PROJECT SETTINGS
    DVD Label: DVD
    DVD Menu: No Menu
    PREFERENCES
    Video Resolution: 0
    AC3 Audio Encoder: 2
    DVD Audio Format: 0
    Normalize Audio: 0
    Save Log file: 1
    Subs:
    AVISYNTH SCRIPT
    Audio = Audio.GetChannel(1,3,2,5,6,4)
    HCenc Parameters: -ini "C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_2_Cutthroat Island.HCenc.ini"
    HCenc ini file:
    *INFILE C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_2_Cutthroat Island.avs
    *AVSRELOAD
    *OUTFILE C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\DVD_2_Cutthroat Island.m2v
    *LOGFILE C:\Documents and Settings\vicsedition\My Documents\Convert_Xfer\Temp\DVD_2_Cutthroat Island.HCenc.log
    *MAXBITRATE 9000
    *BITRATE 4419
    *PROFILE BEST
    *ASPECT 16:9
    *PROGRESSIVE
    *BIAS 40
    *DC_PREC 9
    *MATRIX MPEG
    *AQ 1
    *LUMGAIN 0
    *SMP
    *PRIORITY IDLE
    *WAIT 2
    <3/18/2010 1:39:28 AM>
    PROCESS ABORTED DURING TITLE 1 VIDEO ENCODING OPERATIONS.
    CHECK LOG FILE <C:\DOCUMENTS AND SETTINGS\VICSEDITION\MY DOCUMENTS\CONVERT_XFER\DVD_2.LOG> FOR MORE INFO.
    This is all I can see so I leave it to those more educated...
    I do know that I get very strange results at times concerning my m2ts'.... most work great... like I said another m2ts I converted previously completely errored and then resulted in a completely dvd compliant video... I don't understand.
    This particular one actually got through by selecting the 1 pass as a locked bitrate and then I let it do its thing... various errors ensued and it never forced me to abort always leaving the option to close and continue a new set of operation (backup ffmpeg) which said it had buffer read allocation errors and then produced a completely working dvd... like I said I don't get it... my source files come from mostly the same source and I see identical input data through mediainfo but still receive errors on some files... I thought it was just the wavi+aften but now I'm wondering if the m2ts format is difficult? Of course I know nothing and hope you can help me..! Your program is completely awesome as I have made a switch from avs4you to avs2dvd... hopefully no one tires of my newb status and works me through! 'preciate it...
  8. It could be related to your AC3 filter mixer configuration (3/0/2+LFE for 5.1 channels audio). If you are using ffdshow (alone) as AC3 decoding filter, AVStoDVD will adjust mixer for you. If not you have to do it manually before encoding.
    Bye
    MrC
    AVStoDVD Homepage
  9. ok I think we might have something here... I looked into my codec pack (CCCP) and under its ffdshow audio I have it set for 2/0/0 - stereo... is this the problem? I did default installs of CCCP first and then avs2dvd... I went with the flow as I'm newb... should I change this to your suggested 3/0/2+LFE ? I noticed that CCCP has the ability to configure just the ffdshow audio but I don't know what I'm doin in there. So I have selected on its "main settings" menu under ffdshow audio settings to that suggested 3/0/2+lfe and I will retry... I understand you have nothing to do with CCCP but if you have any info concerning these settings making my life easier with avs2dvd it would be great! Thanks for your time man...
  10. It seems that all good things come to those who wait! Re-registering my CCCP settings to include 3/0/2+lfe worked like a charm... so the answer was to select the audio encoder as Quenc and to take care of said 5.1 issue and BAM! Thanks fer all the pointers... this thread can now be closed for me... avs2dvd rocks keep it up.
  11. Well everything is fine and dandy except selecting new ffdshow audio settings in CCCP seems to only last as long as the computer is on. Once rebooted it continues to revert back to 2/0 stereo... does anyone know if this is normal? Am I missing a step? I'd like to skip reinstalling CCCP (so I can initially select the proper 3/0/2+lfe channel) ... I do have stereo speakers attached to the computer so I'm also wondering if watching through MPC or VLC or WMP9 would somehow reset it the 2/0... don't really think so but I'm total newb and wouldn't know.
