ya i know there are alot of these posts out there and none of them have help me out that i have seen so far. what i am trying to do is change a source that is originally 23.976 fps up to 29.97 without changing the length of the video. i tried using ChangeFPS(29.97) and that changed the fps but made my 1 min test clip about 15 secs shorter. the main reason i need to do this is that i will need to append one clip that i have to another in MKVMerge and i cant have conflicting fps. i would also rather add frames than destroy frames so converting the 29.97 down is out of the question. my current AVS Script is below but, as i said earlier, the ChangeFPS() does not keep the length of the clip correct. so my main question is what will i need to do to get the FPS up to 29.97 without changing the length. im open to any suggestions on how this can be done.
Code:LoadPlugin("C:\Program Files (x86)\megui\tools\dgavcindex\DGAVCDecode.dll") AVCSource("A:\stuff\D1\OP.dga") ChangeFPS(29.97) LoadPlugin("C:\Program Files (x86)\megui\tools\avisynth_plugin\UnDot.dll") Undot() # Minimal Noise
ConvertFPS(30000,1001) will give you 30000/1001 , or if you want ConvertFPS(29.97) which is an approximation. If you are attempting to append, it has to match the other clip exactly
or use frame interpolation like mflowfpsLast edited by poisondeathray; 15th Mar 2010 at 13:54.
really? convert instead of change.......
thanks i'll test this out and report back if it was successful. -
assumefps, convertfps, changefps are all slightly different in what they do . You can read about them
http://avisynth.org/oldwiki/index.php?page=FPS
Anyways, I suspect you're going to have difficulty in appending. It's not that easy. Everything has to be correct, even encoding settings. -
ya i know im encoding everything exactly the same. this is the only field that was different and somehow it appended it with the different fps's. but there wasnt any video after the append and that is what tipped me off that something wasnt the same. also thanks for that link.
EDIT: yes that seems to work and the append also worked
thank you again.
ConvertFPS() will give you blended frames (double exposures). You can also try one of the frame interplation filters in AviSynth like SmoothFPS():
You need MvTools to use this. For some types of material it works very well. For others the artifacts are too distracting.#Import("C:\Program Files\AviSynth 2.5\plugins\SmoothFPS.avs")
#requires MVTools
function SmoothFPS(clip source, float fps) {
fp=fps*100
backward_vec = source.MVAnalyse(isb = true, truemotion=true, pel=2, idx=1)
# we use explicit idx for more fast processing
forward_vec = source.MVAnalyse(isb = false, truemotion=true, pel=2, idx=1)
cropped = source.crop(4,4,-4,-4) # by half of block size 8
backward_vec2 = cropped.MVAnalyse(isb = true, truemotion=true, pel=2, idx=2)
forward_vec2 = cropped.MVAnalyse(isb = false, truemotion=true, pel=2, idx=2)
return source.MVFlowFps2(backward_vec,forward_vec,backwar d_vec2,forward_vec2,num=int(fp),den=100, idx=1,idx2=2)
ChangeFPS(29.97) keeps the length exactly the same as the original 23.976fps video. Either you did something else in the script if the length is really shorter (like use AssumeFPS instead, perhaps), or whatever you're using to show the length is showing it incorrectly. ChangeFPS(29.97) adds a duplicate frame after every 4 frames, while playing it at the faster framerate. The length remains the same.
That page is out-of-date. Use this one:
http://avisynth.org/mediawiki/FPS
As Manono said, ChangeFPS does not change the video duration.
Audio track from 25fps video with a 23.976 fps video
By cedworld in forum AudioReplies: 12Last Post: 22nd Apr 2014, 09:31 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 18:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 09:03 -
Difference?? 23,976 pics/s or 29,976 fps
By twanbaten in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 11:29
