Just checked this out for the first time, using it to remove a couple minutes worth of extraneous material at the tail end of a Divx-5 AVI video file. I had no guide or instructions, but it seemed fairly straightforward. It looks like the Save after edit did a re-encode. I can burn this for playback (not on the computer, as I prefer to judge these things on a better and larger display), in order to do a direct comparison with the original, but am I likely to find any any significant loss of PQ ?
In the Avidemux menus, I noticed items for building an MPEG index, or rebuilding one. Is this comparable to the video file repair feature in VideoRedo ? (Except that the one in VRD works with .MPG only ?) I think Womble may have such a feature also, but would have to double-check that.
	When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
	If you cut only on a Key Frame and select COPY for both video and audio it should not re-encode anything. When you import an MPEG file into AviDemux....it automatically asks you if you wish to build an index. I doubt it has anything to do with "repair"....but I could be wrong.
	The section cut out started on "black space" -- nothing visible there -- so I could not say if that was a Key Frame or not. I did not chose COPY, though. Just marked the Begin "[" and End "]" section points, then chose CUT. The apparent re-encode occurred when I saved the slightly shorter file. I did not know about other ways to skin the cat . When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
  intensity pro quick couple of questionsBy digitalpimp in forum Capturing and VCRReplies: 8Last Post: 31st Dec 2011, 18:22
  intensity pro quick couple of questionsBy digitalpimp in forum Capturing and VCRReplies: 2Last Post: 23rd Nov 2011, 19:34
  Avi resizing or creating quick dvd using avidemuxBy striker9 in forum Video ConversionReplies: 13Last Post: 2nd Nov 2010, 12:01
  Couple quick Panasonic AG-1970 questionsBy pgoelz in forum RestorationReplies: 13Last Post: 4th Mar 2010, 18:22
  Quick AVIdemux question!By janlafata in forum EditingReplies: 16Last Post: 17th Mar 2009, 02:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
 w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
 though not yet assigned to that task]
Shuttle SH67H3 (i7)
 w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
 services for an office, with other computers
 there . . . ]
Various older model Lenovo laptops, like T-40
  series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
 & various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
