I'm on Windows Vista Home Premium 32-Bit Service Pack 2
Up until a few months ago I had been using one of the pre-beta 7 nightly builds (I don't remember which one) without any problems. When I finally decided to update to one of the more recent ones, uninstalling the old one then installing the new one, ffdshow VFW codec no longer showed up as an option to be used !
As in, it won't show up in Virtual dub, Camtasia, or any other software that supports/relys on vfw codecs.
I've installed xvid and x264 vfw's and they show up just fine. xvid works, but strangely x264 gets errors.. I don't know if that is any constellation to this problem.
Any help on the matter would be appreciated.
I was really hoping someone could help me figure out what the issue is.
I'm thinking it's because I updated to Service Pack 2... confirmation or negation of this would help at least.. -
Been a while again sorry.
Uninstalling , reinstalling, rebooting (the regular troubleshooting) failed to help. I wish it was so simple.
I uninstalled SP2, no difference. Can't get the VFW to show up on any application.
I no longer get x264 errors (note that I used x264vfw which is now updated so that may have corrected itself) but it has nothing to do with ffdshow anymore.
Thanks for the suggestion.
VDub and ffdshow: Encoder option empty for mpeg4 (Win 7)
By nbarzgar in forum EditingReplies: 3Last Post: 8th Jun 2011, 14:32 -
VFW ffdshow Settings to Edit flv in Vdub
By kaskaļ in forum Newbie / General discussionsReplies: 15Last Post: 1st Jun 2011, 12:40 -
VirtualDub x64 with ffdshow vfw x64 no H264
By SandyB in forum Newbie / General discussionsReplies: 8Last Post: 10th Aug 2009, 18:45 -
Encode to Theora with VFW/ffdshow
By TheParadox2 in forum Newbie / General discussionsReplies: 16Last Post: 15th Jul 2009, 04:10 -
ffdshow, vfw and x264
By Gigaplex in forum Newbie / General discussionsReplies: 6Last Post: 21st Oct 2008, 18:02
