Hi guys, sorry for my english. I have this dvp5990 and I was wondering about buying the PQI H560 500GB. My question is, will it work? I was reading about power limitation and I'm not sure. I know about file limitation - 300 folders and 648 files each. Thanks for reply!
Tom
Results 1 to 12 of 12
I don't know about this particular drive, but here are some general rules.
Drives with external power (that means you must connect the drive to electricity) are best. Drives that get power via USB may or may not work.
The drive will need to be formatted as FAT32. -
Hmm... thanks for reply
so u think that 500GB 2,5" will not work
? Please answer it's very important becouse I don't know which type of disk should I buy, 2,5" or 3,5". Greetings
The DVP5990 user manual says that "The USB socket does not support the connection of other USB devices except to a USB flash drive." Better borrow external drive with external power for a test.
A 2.5" external drive will probably work because it uses a low power laptop drive.
When USB support is limited to Flash Drive, it means that the device can't supply the load with 0.5 A current, which is necessary for 2.5'' external HDD. This type of external HDD is not so low power as somebody may think.
Again, better make a test. Or buy another DVD player without such restriction. Philips DVD recorders are not quite reliable anyway. -
Many people with Philips DVP-5990 DVD players are using 2.5 inch external drives without external power. Obviously, you won't know until you've tried or found someone else how has the exact same drive.
Worst case, you could use a USB power booster Y adapter cable and a wall wart:
http://www.amazon.com/USB-Power-Adapter-Y-Cable/dp/B000JIOHDE
http://www.amazon.com/Lenmar-AC-Adapter-USB-Powered-Devices/dp/B000VNKGM8 -
my wd 250gb(2.5) works with no issues .I'm not sure if the 500gb size is the issue or the external enclosure chip isn't compatible with certain players
Philips 5990 need advice on what HDD to get.
By s-toon in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Sep 2010, 13:14 -
USB Problem with Philips DVP 5990
By bufbt in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2010, 13:52 -
Philips DVP 5990/37 HDD issue - need help
By badboo in forum DVD & Blu-ray PlayersReplies: 8Last Post: 20th Feb 2010, 15:27 -
DVD Philips DVP 5990
By heidizwygart in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd May 2009, 06:48 -
Philips DVP 5990/37 question.
By s-toon in forum DVD & Blu-ray PlayersReplies: 16Last Post: 12th Apr 2009, 16:44
