Bought VOB2MPG and am slightly disappointed with it.
I was under the impression that this was a one click DVD backup solution as I was intending to use this to rip my DVD's onto my hard-drive so I can stream them to my PS3 via PS3MediaServer.
If I run VOB2MPG on a DVD (Munich for example) it runs fine but the resulting file has no picture or sound (on either my computer (played on both WMP and SPlayer) or PS3)
IF I run the DVD through DVD Decrypter then run VOB2MPG on those files it works perfectly.
Is this correct? Will I have to use DVD Decrypter before I use VOB2MPG for all my DVD's?
Next you need to choose your DVD source and output folder. DVDs can be a disc or a folder on your hard drive, encrypted DVDs are not supported but you can use on-the-fly decrypters is you wish.
http://www.svcd2dvd.com/VOB2MPG/default.aspx
slightly disappointed with ms, xbox live, and zune but not unexpected
By yoda313 in forum Off topicReplies: 0Last Post: 1st Jan 2010, 21:27 -
Disappointed with Sony DRU-190A - lots of coasters !!!!
By paulfoel in forum DVD & Blu-ray WritersReplies: 6Last Post: 26th Feb 2009, 15:56 -
slightly OT: Is ripdifferent.com forums down?
By terryj in forum MacReplies: 10Last Post: 5th Sep 2008, 20:51 -
slightly OT: Words to live by
By terryj in forum MacReplies: 0Last Post: 17th Jun 2008, 13:11
