Hi folks,
I thought I would post this here since it took hours of scouring the web to find the right info.
The remote hack listed for the Momitsu 899 does not work for the Momitsu 799. I tried all variations I could find of the 899 hack with no luck. Here's the correct hack for the 799:
1. Make sure no disc is in the drive, and the tray is closed. (Took me awhile to figure out that last bit!)
2. On the remote, push 8751+A+B
A= DVD region codeAnd for "A" at least, "0" does not work as an all-region code.
B=Blu-Ray region code
When I first got the thing, it wouldn't play certain DVDs - took me awhile to figure out that it was set to another region, and was rejecting my region 1 discs. I've heard that the 899 will actually tell you that's why it's rejecting a disc, giving you some screen saying something about the region. The 799 however will not do that - the little spinning disc icon in the top right of the screen just quickly flashes with the letters "dvd" next to it, then automatically ejects the disc. I thought I had a couple of badly scratched DVDs until the region thing occurred to me.
I found a post on some other forum (can't remember which! sorry!) where some other guy figured out the same thing, and had to change the region to region 1 so he could play his American dvds. That's where I found the correct code for the 799.
Anyway, since most of the posts here and on other forums I found listed the hack for the 899 (9751+a+b) as working for the 799, I figured I should let you guys know that it doesn't work - at least on mine.
thanks
ojo
Results 1 to 1 of 1
Warning for Momitsu 899 and 799 and clones owners
By oldfart13 in forum DVD & Blu-ray PlayersReplies: 68Last Post: 3rd Nov 2013, 15:09 -
Oppo 83 Vs Momitsu 799
By punkuk in forum DVD & Blu-ray PlayersReplies: 7Last Post: 9th Jun 2010, 20:31 -
Momitsu 799/899 PUO skip
By ojopaj in forum DVD & Blu-ray PlayersReplies: 5Last Post: 14th Mar 2010, 08:46 -
Sony DVPN S708H hack using the dvd remote
By desertoil in forum DVD & Blu-ray RecordersReplies: 1Last Post: 8th Apr 2009, 17:22 -
GoVideo DVP853 DVD Hack with One For All 4 Remote ??
By culttvguy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Apr 2008, 12:17
