What is meant by "noise around the edges"?
Results 1 to 9 of 9
Overscan, maybe? See this: Errors on the edges of converted VHS tapes?
I guess this question is related to this thread:
https://forum.videohelp.com/threads/80047-Pixelization-of-Edges-of-Objects-in-a-Scene
You'll have to provide a sample. But it sounds like you're talking about interlace comb artifacts. -
Thanks so much for the reply.
ok.
If you look at the sample...
Around the faces, hands, shirt...
They are like... rough.
This normally happens when there's movement.
How can this be fixed?
Thanks. -
Yes, those are interlace comb artifacts. For viewing use a player that can deinterlace on-the-fly. VLC, MPCHC, KMPlayer... If these are downloaded files from Youtube they may not be fixable. If you want to upload interlaced material to Youtube or other online streaming sites you should deinterlace first.
https://forum.videohelp.com/threads/300274-Capture-Settings-Weird-lines-in-final-produc...=1#post1836133 -
Thank You jagabo.
If I deinterlace the video, can it play on most modern dvd players and tv?
Thanks. -
Yes, but it'll look like shit. You want the interlaced version for TV.
rougher edges than in the original...
By Weef in forum Video ConversionReplies: 55Last Post: 17th Aug 2010, 12:19 -
blurred edges
By mathmax in forum RestorationReplies: 50Last Post: 2nd Jun 2010, 10:22 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
odd edges Artifacts?
By mark439 in forum Newbie / General discussionsReplies: 2Last Post: 30th Jan 2009, 12:21 -
Question why edges cuts off
By tofuguy in forum Authoring (DVD)Replies: 2Last Post: 26th Oct 2008, 02:09
