Is their a way to get around this error in virtualdubmod? Because dowloading codecs (xvid) is not working!
Plz help
[!] Couldn't locate decompressor for format 'xvid' (unknown).
VirtualDub requires a Video for Windows (VFW) compatible codec to
decompress video. DirectShow codecs, such as those used by Windows Media
Player, are not suitable. Only 'Direct stream copy' is available for this
video.
Have you tried install koepis xvid codec? https://www.videohelp.com/download/Xvid-1.2.2-07062009.exe
Warning applies to code xvid or XVID?
BTW
Try latest Jawor's Xvid build.VideoAudio.pl - Serwis o technologii wideo & audio -
Yes I have but i still get the error i mentioned! I also installed the latest K-Lite Coded package and i install Divx Pro, but no luck.Baldrick
Re: Virtualdubmod errors?
Have you tried install koepis xvid codec? https://www.videohelp.com/download/Xv...2-07062009.exe
I have Windows 7 Ultimate if it matters, i never had this problem on Vista. -
Well is xvid and XVID the same thing?Placio74
BTW
Warning applies to xvid.
Thanks placio will give that a try and report back here! -
No, not same.
Xvid codec inserts XVID FourCC code (and this is expected later to handle).
FFmpeg encoder by default inserts xvid FourCC code (ffdshow VfW can handle this).
From latest Jawor's Xvid build changelog:
The VfW decoder recognizes both lower- and uppercase FourCCs
Other ways...
- set Ask for extended options after this dialog when open file in VirtualDub and use Force video format FOURCC code to XVID,
- or use FourCC Changer and fix FourCC code,
- or use ffdshow VfW which can handle lowercase FourCC.VideoAudio.pl - Serwis o technologii wideo & audio -
Learned something new thanksPlacio74
No, not same.
Other ways...
Yeah!!!!!!!Thank You so much Jawor's Xvid Build Perfectly no more errors Thank You! Gracias
I always thought it odd that the official (koepi's ?) didn't support LC 4cc . No biggie, at least there's an alternative.
What should I use instead of VirtualDubMod?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 02:06 -
Need help with VirtualDubMod
By Brakiri in forum Newbie / General discussionsReplies: 3Last Post: 17th Dec 2010, 05:28 -
Virtualdubmod
By Irolaan in forum Newbie / General discussionsReplies: 0Last Post: 19th Sep 2009, 12:57 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
