I have a Sony DW-Q28A dvd burner and always worked perfectly for years.
But now I cannot burn DVD+R anymore.
I tried it with Nero and IMGBurn. IMGBurn doesn't give an error and the dvd looks burned, but I cannot play the dvd on my computer or on the stand alone dvd player.
Today I tried a DVD-RW with IMGBurn and no problem.
I also found the firmware for the burner, but I get this message:
"No matched drive detected. This utility is only for Sony DVD-RW DW-Q28A drive. Detected drives: (0) "
Anyone have an idea what could be wrong and how to get the firmware working?
If older firmware is available (Or newer firmware) you can try that. But generally firmware shouldn't cause the problem you mention, unless you changed your DVD media recently and what you are using isn't compatible with the burner. Still, you should have gotten an error in the ImgBurn burn log. If you didn't, then maybe time to replace the burner.
But I would try some different brands of DVD media and see if that helps first.
And welcome to our forums.
New burner burns SLOWLY
By will7370 in forum Newbie / General discussionsReplies: 14Last Post: 23rd Feb 2012, 22:01 -
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
Is it possible to flash firmware onto a non-original DVD burner???
By suomalainen in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2009, 17:17 -
Samsung SH-S203N SATA DVD Burner stops responding during burns?
By 1wheelken in forum DVD & Blu-ray WritersReplies: 84Last Post: 24th Aug 2009, 14:30 -
Laptop DVD Burner suddenly only burns small portion of DVD
By hydrurga in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Feb 2008, 04:39
