Hi all
I'm using VOB2MPG to convert the first season of Entourage. Although the VOB files contain English and French language audio streams, VOB2MPG only picks up the French regardless of which one is selected. I'm able to watch the English version in the original VOB format so I don't understand why VOB2MPG is having trouble.
I should also say that the only other audio stream available on the dvds - the commentary - converts satisfactorily.
Any advice?
Pro version?
Hi Chris,
I solved the problem by reading this thread (which didn't turn up on my first search of the forum) : https://forum.videohelp.com/threads/314429-VOB2MPEG-Pro-Language-problem?highlight=preview
I had to manually select the English audio stream rather than use the default.
I would also like to ask you about the preview function on my copy of VOB2MPG Pro. After going through your suggestions on the sticky, it works but usually only plays a particular chapter (generally the first sequence from the source dvd ). It doesn't respond to attempts to select a different one.
Regards.
A Holiday Season Shoutout To All
By budwzr in forum Off topicReplies: 15Last Post: 28th Dec 2011, 22:44 -
a complete season of a tv series on a 4.7 gb dvd
By Sanmaame in forum Authoring (VCD/SVCD)Replies: 2Last Post: 2nd Feb 2009, 19:44 -
As the Pats ended perfectly their season,...
By moviebuff2 in forum Off topicReplies: 9Last Post: 3rd Jan 2008, 05:51 -
Ripping Whole Seasons...Entourage
By EliteMarine in forum DVD RippingReplies: 9Last Post: 19th Dec 2007, 20:31 -
i have spiderman season 1-5 and its .avi. can i burn each season on dvd?
By dizzlenizzle87 in forum Newbie / General discussionsReplies: 7Last Post: 8th Jun 2007, 00:23
