I'm buying a sound regulator (TERK VR1) that sits between my DISH box (VIP722k) and HDTV to get rid of the loud commercial bursts. Problem is, it only accepts RCA cables in/out for audio signals. I'd hate to lose my HDMI video quality to the TV- and wondering if anyone knows how to disable the HDMI audio so I can use this.
Otherwise, I've got to go all RCA (RYG/audio).....will the video quality really drop that much?
Your video quality won't drop because you'd still use HDMI for that. As long as you don't have a 5.1 or greater speaker set, you won't notice a huge difference. The real issue you're going to have is that the Terk device doesn't reduce commercial volume enough to solve the annoying problem from which we all suffer.
I have a Samson dynamic range compressor between my PC and speakers to regulate the volume difference between Youtube videos. It works pretty well, but there's still 20% of the time where I have to ride the volume control on my speakers because some video was encoded so loudly."Quality is cool, but don't forget... Content is King!" -
Wait. I'm going from my sat-box to HDTV with HDMI. (If) I use RCA for audio into the TERK then to the TV - will that disable the audio going through the HDMI cable for video. The reviews posted on the TERK are all good - for the price it looks like it's at least worth it to try and dampen the commercials.
(If) I have to go RCA for both video/audio - in your opinion will I see that much difference in video quality vs HDMI? -
Depends on your TV. If it allows you to use an alternate audio source while using HDMI, should probably work.
I got around the problem by outputting coaxial audio from my sources directly to my surround sound amp. My HDMI display (Projector) doesn't have audio, so no problem there. I would check your TV manual.
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 16:33 -
Need help with HDMI, DVI-HDMI and "high definition audio device"
By uart in forum Newbie / General discussionsReplies: 7Last Post: 16th Mar 2010, 00:15 -
Disable HDMI audio
By JOHNINA in forum DVD & Blu-ray PlayersReplies: 5Last Post: 28th Feb 2010, 09:58 -
Can't disable audio normalization?
By ngibbs in forum ffmpegX general discussionReplies: 3Last Post: 28th Apr 2009, 16:18 -
Disable audio in Avidemux
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 22nd Sep 2008, 10:15
