  1. one part of the dvd has multi-angle feature, i can choose which angle to see from when i play it with dvd player
    how can i compress the dvd with this feature by using virtualdub?
    thanks
  2. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Re-author it first with the angles removed?
  3. actually, i even cannot find those diferent angles in the dvd
    are those also *.VOB ?
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVDDecrypter can rip one "angle" or branch....that's if your movie is not too new for DVDDecrypter's protection removal.
    I'd also try DVDFab.
  5. i'm now trying DVDDecrypter, hope it works =)
    btw, how to rip all five angles and get 5 viedo?
    i tried and it is still the same...
    repeating each lyrics five times with five angles
  6. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by UMO View Post
    ii tried and it is still the same...
    Did you use IFO Mode or File Mode?
  7. thanks so much!
    i can do that now~
    so can compressed the dvd into one *.avi file with that multi-angle feature?
    i tried couple time
    but still got the same result:
    part 1 and 2 - wrong ratio, 16:9
    part 3-6, correct ratio, 4:3
    how to solve this problem?
  8. Member Cornucopia's Avatar
    Just like how MPEG or AVI files combine an audio and a video stream together by "Multiplexing" or MUXING them (kind of like how a zipper zips together 2 sides), a multi-angle DVD has multiple video streams muxed together into a single VOB file.
    Now remember, in DVD-Video, since there is a 1GB file limit on the UDF formatted disc, this multiangle VOB file might get chopped into pieces (e.g.: part 1 of 2, part 2 of 2). You'll see this as VTS_01_1.VOB, VTS_01_2.VOB, etc. Each segment contains ALL the angles (assuming the angles run through the entirety of the show).
    Can you put this all into 1 AVI? Yes. But it's not easy to do. Have to use certain tools and multiple steps.
    Will it play as you were thinking? Not unless you use a "Multi-angle AVI-aware" app (only a few out there).
    If you want to scale this mountain for a few rare benefits, PM me, but be forewarned...
