They all use the same high quality h264 encoder (x264.exe) so the difference won't be very much.
"Quality is cool, but don't forget... Content is King!" -
I wouldn't blame x264! Blame your sloooooow cpu! BTW. Nothing is for free. High quality = advanced algorithms enabled in x264 which require cores*Mhz.
Dual-core is a low end machine for video encoding. For example Intel i7 cpus are the best cpus for this task at the moment. Especially the new one with 6-core
Beast!
You're certainly right. But I don't need so much power right now, this is an exception.
Going i7 now would mean changing cpu, mobo and memos: too much money. I might consider a quad cpu first for my setup. -
Another question related to x264.
What happens with the audio file? Do I have to demux the original ac3 from the 1080p mkv? Will it be in sync?
I ask this because I've had cases where the audio file, when converting to DVD files which is not the case here, did go out of sync. H264 files do seem to have such problems, I think.
Edit:
Well, things did not turn out too fine. Movement is faster than it should and audio is out of sync. I wonder what should I put on the setup to make it work. My guess is it's probably a setup thing. I would also like size to be larger than it is, as that might provide me a better quality.
Where can I find instructions on how to set things up?Last edited by carlmart; 14th Mar 2010 at 08:37.
Simplest way to convert 1080p h264 mkv to 720p mkv?
By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 10:16 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35 -
25fps 1080i mkv convert to 24fps 1080p or 720p mkv?
By brent1a in forum Video ConversionReplies: 6Last Post: 9th Feb 2010, 09:57 -
AutoMKV: 1080p or 720p MKV to smaller sized 720p MKV = choppy video!
By Quicky in forum Video ConversionReplies: 1Last Post: 12th Apr 2009, 19:23 -
1080p mkv to 720p mkv?
By nick101181 in forum Video ConversionReplies: 1Last Post: 1st Jan 2008, 14:04
