I don't believe it does support aspect ratio tags. What is the actual resolution of your image ? Wild guess, shot in the dark, I bet it works out at 3:2 in square pixels.
Lagarith is intended as an intermediate codec for lossless intermediate encoding. AR is not so important because you can usually tell your editor what AR a clip is supposed to be, and most end delivery formats (Mpeg-2/4 etc) do support AR tags.Read my blog here.
Hehe, and I'll go even farther out on a limb and hazard the guess that it's 720x480.
As the man says, Lagarith is only used as an intermediate file before reencoding to something else (MPEG-2 for DVD perhaps?). If for some peculiar reason of your own you have to check it out at the correct aspect ratio, make the change in a player. Since you've looked at the Configure portion of the Lagarith Codec and haven't seen any way to set a DAR, I think you can logically conclude there isn't a way to do that. Set the DAR in your MPEG-2 encoder (if that's the ultimate output format). -
Thanks everyone, it was 720x480 and it turns out Gspot assumes square pixels unless being told otherwise.
Btw - My question was not about Lagarith but GSpot and how it displays AR. I was confused because I was certain Lagarith doesn't store this information or care, and yet GSpot was implying that it did.
Multiple Aspect Ratios on One Disc
By gorcq in forum Authoring (DVD)Replies: 7Last Post: 20th Dec 2011, 21:35 -
Aspect Ratios: 0.889 vs 0.9191
By Hass860 in forum Newbie / General discussionsReplies: 15Last Post: 13th May 2010, 03:14 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 10th Mar 2010, 23:18 -
multiple aspect ratios on one DVD?
By towtruck in forum Authoring (DVD)Replies: 11Last Post: 7th Jul 2008, 02:58 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 15:13
