Can anyone help with this? There is no hack code listed so I tried some others that looked similar models. They basically say
1) open dvd tray
2) press set up
3) select preferences
4) enter code 138931
i get the set up menu but it does not say preferences anywhere. I have quick set up and custom set up but no preferences in sight. Help!!
Same problem here!!
No preferences anywhere
(I know it's almost 2 years but i didn't want to open new topic for the same problem) -
1) Some DVD players can't ever be unlocked. Maybe this is one of them.
2) Most BluRay players can't ever be unlocked. If you do unlock them, it's almost always only for DVD playback and not for BluRay playback.
3) Almost nothing made by Sony or Samsung can be unlocked.
4) Sometimes manufacturers make hardware and/or firmware changes that break hacks that worked in the past. In the case of firmware, if you can find older firmware to install and the player allows you to do it, it will restore the ability to unlock the player.
5) Speciality players (portables, DVD/VCR combo players, DVD/TV combo players, DVD recorders, home theater systems) usually can't be unlocked.
[newbie] MPEG4 faster + cracking sounds
By yetanotherlogin in forum EditingReplies: 0Last Post: 13th Jul 2011, 02:51 -
Cracking Region Code for LG HT304SLH
By YoungFrankenstein in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Apr 2010, 09:17 -
portable DVD player cracking sounds then hangs
By dzsoul in forum DVD & Blu-ray PlayersReplies: 5Last Post: 29th May 2009, 06:29 -
Is Microsoft Cracking Down on DVD Ripping?
By rkr1958 in forum Latest Video NewsReplies: 41Last Post: 13th Feb 2008, 08:49 -
Help with popping & cracking sound from pc
By gyles in forum AudioReplies: 1Last Post: 12th Aug 2007, 13:54
