  1. Hi!!!
    Big Picture - I am looking to create training videos for my company on individual position tasks and procedures.
    Details - I am looking for a software that will allow me to do the following:
    * Narrations (Voice Overdubs)
    * Cut/Paste Video
    * Add Music
    * Graphics
    * Burn to DVD format
    These are easily identifiable and readily availible in most software applications. What I have not specifically seen that I am looking to do is:
    * I want to be able to insert "text slides" in the video footage. The best example I can give is the old time movies where you would see live footage, then a slide that would show the dialouge, back to live footage, back to another slide and so forth.
    My specific example would be - text of task about to be seen, video of the task being compelted and then slide text reveiwing specifics of tasks.
    1. What is the appropriate descritpion of what i want to do?
    2. Any advice on a specific software that allows this type of editing?
    Bill
  2. Member Soopafresh's Avatar
    Jan 2004
    A bunch of different apps can do this, I'd suggest Sony Vegas (there are 5 or 6 different versions and price ranges, so check the features for what you need). Vegas is pretty stable. As with any new app, you've got a learning curve ahead of you.
    "Quality is cool, but don't forget... Content is King!"
