HI! First, excuse my bad english...
I actually have an external drive that I want to connect to my samsung P-390 DVD player. I know this dvd-player only recognise the FAT32 file system so I create a FAT32 partition (50 gigabytes) on my external drive (originally NTFS). But, it still doesn't works... Is my partition too big? It works well with a USB key...
I think the partition size is OK. I used one of my 500GB hard drives and created a single partition and it works fine with a Philips 5990 player with USB inputs. What did you use to create the partition? I've only had luck with SwissKnife: http://www.softpedia.com/get/System/Hard-Disk-Utils/CompuApps-SwissKnife.shtml
I don't know if multiple partitions will work if you also have a NTFS partition on the same drive. Never tried that.
And welcome to our forums.
Samsung micro USB-B to USB-A cable
By luigi2000 in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2011, 15:05 -
Which hdtv's have a USB port, so you can plug in a flash drive or USB HDD?
By snafubaby in forum DVB / IPTVReplies: 8Last Post: 30th Nov 2010, 17:03 -
samsung p390 playing usb drive
By aajmac in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2009, 21:34 -
Samsung P1500 and AVCHD via USB
By conflyto in forum DVD & Blu-ray PlayersReplies: 0Last Post: 6th Jul 2009, 20:57 -
Using 500GB usb drive as player on Standalone with USB
By OdubruS in forum DVD & Blu-ray PlayersReplies: 5Last Post: 26th Jul 2007, 06:36
