Avidemux works only on some mkv files and even if it worked, frame accuracy is all messed up (Avidemux kept complaining/warnings about B frame) .
I tried mkvtoolnix-unicode-3.2.0-setup.exe, but was told by this program that every mkv file I loaded got NO chapters? (most of my mkv files are 6 - 8 GB and they all have at least 4 - 5 scenes in each of them).
Any help will be much appreciated!
p/s what's the best tools for editing mkv files? a)free and b)paid, thanks.
Highly compressed formats have keyframes (I Frames) widely spaced, so frame accurate editing is very difficult. That's one way they achieve high compression. All editors will have the same problem unless they re-encode the whole file, or at least at the cut points. Divx/Xvid uses a 300 frame spacing by default for keyframes. Your MKV is probably similar. MKV (Probably H.264) was meant as an end product, not for ease of editing.
One option is to use a intermediary file format and edit in that, then re-encode. Neo Scene is one program for that.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Tool for Editing MKV Without Re-Writing Entire File?
By Wardrop in forum Video ConversionReplies: 3Last Post: 14th Jul 2011, 06:17 -
Video Editing Software: mkv, h264 & DTS Editing?
By techdls in forum EditingReplies: 8Last Post: 28th May 2011, 01:29 -
Improving the conversion of a .mkv file (DTS) to a .mkv file (AC3). Ideas?
By mdelisle1 in forum Video ConversionReplies: 11Last Post: 19th Jan 2011, 10:50 -
Tools for editing MKV file.
By wisitch in forum EditingReplies: 2Last Post: 9th Oct 2010, 00:31
