Hi,
I'm trying to get my bd ripped .m2ts that has .dts to play on my ps3 and KEEP the DTS.
If I have a .mkv file with the same streams and run it thru 'mkv2vob' it will patch the dts and make a mpg that plays fine on the ps3 with dts intact. But it doesn't patch it if you run the m2ts thru it.
So I 'tsmuxer'd the .m2ts and demuxed to elementary streams (.dts and .264) which I ran thru 'mkvmergegui' to make a .mkv file. (mkvmergegui doesn't accept .m2ts as input).
Then, I ran the new .mkv thru 'mkv2vob' and it patched the dts and gave me the expected mpg, which I burned to a dvdr.
720p picture great as expected and sound in fact shows DTS and sounds like it, BUT it's about 2 sec out of sync.
I think it might be during the mkv muxing with mkvmergegui. when adding the .264 and .dts it gave me a message that it couldn't read the fps and told me to enter it manually in the 'format specific options' area. I double checked the .264 file in tsmuxer which shows the frame rate as 23.976 which is what I entered.
close, but no cigar.
any ideas?
thanks,
Jack
Results 1 to 1 of 1
I can't play back .m2ts files with DTS audio
By Quadcam in forum Blu-ray RippingReplies: 3Last Post: 24th Nov 2011, 16:31 -
Can't get a 1080p DTS .mkv to play on PS3?
By leamingtonspaceman in forum Video ConversionReplies: 6Last Post: 27th Feb 2011, 08:40 -
Why WMP doesn't play DTS audio (MKV, M2TS files) ?
By mahogany in forum Software PlayingReplies: 2Last Post: 11th Dec 2010, 14:45 -
DTS Audio not recognized when I play movies from my extern HDD through PS3!
By Spdngblt56 in forum AudioReplies: 1Last Post: 8th May 2010, 17:51 -
Can PS3 play DTS file ???
By luckymefella in forum Media Center PC / MediaCentersReplies: 4Last Post: 5th Nov 2009, 17:48
