hi all ,,,
I want to know how to paste IDX Subtitle on MKV movie ,,, to make it play with the movie on samsung LCD
Don't know about playing on the Samsung lcd but I have used MKVmerge to mux idx/subs into a MKV. You don't put both the idx and sub into the program. You just insert the idx and the program finds the sub if it is in the same folder and inserts it.
Also, most players will play external idx/subs if they have the same name as the MKV file and they are in the same folder.
Tony -
thx tony for ur replay,,, but look ,, I want to paste IDX or SRT Subtitle with MKV file to make the movie and the subtitle in one file(MKV) to play the movie on samsung LCD with the Subtitle ,,, I want to make the subtitle and the movie in one peace because my samsung LCD don't play IDX subtitle ,,, it can play SRT but with bad font ,,, because all of that I want to paste the subtitle with the MKV ,,, I try MKVmerge ,, it mux the IDX with the mkv ,, but when I play the movie in the PC or LCD subtitle doesn't show ,,, and I don't know why??? plz help me
Moving you our subtitle section. And you don't have to make the text bold and huge...
It would depend on a number of things including what the MKV resolution is. Where did it come from and where did the idx/sub come from? Also how are you playing it?
If you were able to mux the idx/sub into the MKV does MediaInfo show it?
You can generally check out the compatibility of the idx/sub using one of the computer software players. (MPhc,KMplayer and SMplayer. make sure the idx/subs are the same name as the MKV. These players will also play external subs.
Hope this helps
Tony -
Try Handbrake. I believe it burns the subs into the video stream.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Mkv + idx + sub
By dazler in forum SubtitleReplies: 6Last Post: 13th Feb 2012, 13:49 -
How to add idx/sub hard subtitles to mkv
By 2ndlife in forum SubtitleReplies: 5Last Post: 29th Dec 2011, 21:22 -
Can't display embedded Idx/Sub (softsubtitles) in mkv.
By dsteff in forum SubtitleReplies: 1Last Post: 23rd Nov 2009, 23:01 -
Adding .idx and .sub to .mkv ripped by dvdshrink and handbrake
By theredlaugh in forum DVD RippingReplies: 5Last Post: 17th Dec 2008, 11:11
