  1. I demuxed an M2TS file with tsMuxeR and the video file produced was a .264 file. Exact file name: "00006.264"
    I can't find any program that will play it let alone convert it. Any helpful ideas?
    Apr 2004
    Miskatonic U
    VLC and The KM Player might play it, however it is just the video stream from the M2TS file. Any reason why you would demux it to play it ?
    Read my blog here.
  3. why demux it?
    put it into a container like mkv or mp4 or just leave it in transport stream , because most video players cannot play raw avc streams
  4. I'm trying to convert the M2TS file into a format I can edit in Final Cut Pro. Unfortunately, I think the DTS-HD audio is messing things up when trying to convert it. So I want to separate the files and take care of them individually.
    VLC doesn't work.
    @poisondeathray: How can I put it into a container? Any program suggestion? Either Mac or PC is fine.
  5. put it into .mp4 container with mp4muxer or mp4box (yamb is a gui for it)
    or convert it into something with .mov wrapped with ffmpeg e.g. dnxhd , or uncompressed mov, or quicktime animation codec
