  1. I have a BluRay movie that was converted to an ISO. It's about 44GB.
    I do not want to spend big$$$ for a 50GB disk.
    Is there a way to split it into two 25GB or maybe DVDs.
    What programs can I use to get that accomplished and does have to be re-incoded or converted to a different format to be able to do it.
    Feb 2008
    Twin Peaks
    If you ultimate intention is to make a copy of it and you'd like to shrink it to fit on a 25GB BDR https://forum.videohelp.com/threads/299579-How-to-shrink-a-Blu-ray-to-DVD-5-DVD-9-or-BD-25
  3. Guys,
    Using Bd Builder to reencode a blu-ray in an ISO format. Followed the above procedure to make a BD25 and the encode fails at about 85% before completion.
    Any help would be appreciated
