i was wondering is it better to capture in 640x480, and then compress to vcd or to capture in 352x240.
704*480 would be the best then compress and resize to 352*240
i find that stretching the image afterwards does not produce the same quality as stretching the image during capture. could be hardware assisted, could be the uncompressed codec does a cleaner job to begin with.
704*480 down to 352*240 = 1/2
640*480 down to 352*240 = 1/2 + 32 lines stretched, or 32 lines stretched + 1/2
capping to 352*240 is half frame so when the camera pans left or right, you will get more distortion on the screen, like more line scrolling.
of course my card does stretch 320*240 to 352*240 and some cards don't (so I hear). if I cap to 640*480 and encode to 320*240 it looks even better than 704*480 to 352*240 except for screen size or TV out.
if all you can do is 640*480 then that is still much better than 352*240
Capturing with VirtualDub - File size 400GB and only 2 hours from old rec
By Diegovh1 in forum Capturing and VCRReplies: 15Last Post: 28th Jan 2012, 06:40 -
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
How to fit the large size picture to the smaller size for print?
By coody in forum ComputerReplies: 7Last Post: 1st Apr 2009, 08:46 -
small video size, but showing incorrect size (too big)
By mandy in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2009, 04:14
