    Aug 2007
    I want wmp to use coreavc to decode video (h264) from mp4 and mov files but for some reason I can't get it to work. Though when I open these files with mpc-hc, it rightly uses coreavc to decode the video. I checked these files with graphstudio and it shows that coreavc is set to be used but oddly wmp never uses it. If, however, I rename the file with the extension .mkv, coreavc will be launched in wmp. Obviously, this isn't a very good solution to my problem. I was wondering if anyone knows what's going on here. The reason I want to use coreavc and wmp is because it delivers the smoothest playback for all of my HD content compared to mpc-hc and vlc.
    I am using Windows 7 32bit Enterprise, Shark007 codec pack, and coreavc. I was testing it with various movie trailers from hd-trailers.net
    http://downloads.paramount.com/mp/thelastairbender/tvspots/TLA_TVSpot01_Chosen30_1080p.mov
    I was messing with this one in particular. This trailer stutters throughout when I play it in wmp. But if I changed the extension to mkv, it plays perfectly with coreavc/wmp.
    Any help is appreciated.
  2. DECEASED
    Jun 2009
    Heaven
    If I am not mistaken, WMP in Windows 7, by default, is forced to use a different codec for playing H264 in MP4 files. Take a look at this Doom9 thread:
    http://forum.doom9.org/showthread.php?t=146910
    P.S.: The AVC decoder from DivX is faster, better, and also, free.
    Aug 2007
    Thanks for the link, got it working now. I'll give the DivX decoder a whirl for comparison. Thanks for your help!
  4. DECEASED
    Jun 2009
    Heaven
    You're welcome.
