I typically use VirtualDub to capture TV / video stuff with my capture card, and that works fine. Since FFDShow also decodes most codecs, I don't install anything else, because I don't need it.
However, I'm trying to record some Half-Life 2 gameplay videos. The game engine supports saving directly to AVI, and it shows a list of installed codecs, but it doesn't show the FFDShow tab. So, I want to install XviD so it shows up there, but I have no idea if installing it will conflict with FFDShow since I use it to decode video.
So um. Will it? Or won't it?![]()
Ooh, neat!
I just wanted to make sure because I've heard absolute horror stories about people installing stuff like CCCP... I think that was the name, anyway, and then they had lots of problems getting videos to play.
Thanks.
2.35:1 and 1080. Can they ever coexist?
By mpalm887 in forum Newbie / General discussionsReplies: 15Last Post: 13th Jun 2013, 15:52 -
Installing ffdshow to solve codecs problem?
By giunghi in forum Newbie / General discussionsReplies: 11Last Post: 22nd May 2009, 05:42 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
diff. btw ac3, divx, ffdshow codecs???
By geronemo in forum Video ConversionReplies: 0Last Post: 18th Nov 2007, 15:25 -
Can a usb mass storage mp3 player and usb harddrive coexist in vista?
By yoda313 in forum Off topicReplies: 3Last Post: 5th Aug 2007, 18:23
