I've been using the Final Cut Studio for a handful of years now. I usually use aif audio when encoding to DVD just because I think it sounds less compressed.
I'm using Compressor and DVD Studio Pro 4 to build a DVD of a 90 minute feature with Directors commentary plus a helping of extra video tracks for the special features. Using a DVD-5 there's just not room to use a aif audio (especially when there are two 90 minute audio tracks for the feature) so I'm forced to use ac3.
I'm sure we're all aware that there's a volume level difference between ac3 and aif versions of the same file.
When I encode to ac3 I make sure I set the Dialog Normalization to -31 and the Compression is set to none.
To make up for the loss in volume level going to an ac3, I increase the volume level in FCP before I export, even if it makes some of my audio clip in FCP.
When playing back on a set top DVD player, 5 out of 6 players it sounds great. No distortion, no clipping, perfect. But on one player it sounds terrible. The kinda of terrible you feel when you've spent weeks building something and are 2 days past the deadline already and it's now having problems.
I'm wondering if there are any solutions. Is all I can do is lower the levels in FCP and live with the softer sound output of ac3?
Any ideas or suggestions would be awesome.
Thanks!
Yes you can use aif audio for DVD's. That's what I've been doing for years. Even in Compressor when exporting for DVD one of the options for audio is aif. So it's very possible.
I actually ended up NOT increasing the volume in FCP. I left the levels the same, turned of compression, and set the normalization to -31. It sounds great. I might have been wrong in my original post about the audio levels decreasing just by going to ac3.
Distortion in audio
By carlmart in forum AudioReplies: 2Last Post: 3rd May 2011, 14:59 -
Audio distortion
By silveringking in forum AudioReplies: 0Last Post: 26th Jan 2011, 17:13 -
Increasing levels in an AC3 track
By carlmart in forum AudioReplies: 27Last Post: 10th Sep 2009, 07:12 -
How to get two audio levels the same
By TolleyM in forum AudioReplies: 1Last Post: 20th Oct 2008, 10:38 -
audio levels keep changing, 5.1 ac3-to-wave
By spiritgumm in forum AudioReplies: 0Last Post: 22nd Mar 2008, 10:56
