Not sure if I'm wishing but I was wondering if there is a free CD/DVD program that allows you to back up PC games?
I have a few games that I would like to have around for a while and was hoping to be able to have some spare copies just in case something happens to the copies that I have.
Thanks for any help
No, I don't, but with discs costing $0.30 or less each, you can experiment without much risk.
You might also consider reading the Help and/or any instructions that come with the program.
This gives you an overview: http://trial.alcohol-soft.com/en/alcohol_info.php, which was available by clicking on the link in the original link I posted. -
The program states that it works with PS1 and PS2 games but not PC. Regardless what it said I still tried the trial version and it was a no go. Besides that it is a pretty nice program.
First off, PS1 & PS2 games, just because you mentioned those, even though it will make copies of the games, as will dvd decrypter or pretty much any cd/dvd copy program, they will only play on a MODDED console.
You can not just make a working copy of a console game.
The same is true for a pc game.
It is VERY hard to make a PC game backup that will actually work without a fixed .exe or some kind of hack.
And if you have a DL PC game, all you have to do is copy the contents to your HDD, then split the files across 2 SL dvd's.
But without a fixed .exe or some type of hack, you will still have to use your original disc's in your drive to verify you have the game and play it.
EDIT:
Sent you a PMLast edited by Noahtuck; 9th Mar 2010 at 22:55.
How do you backup your o/s?
By johns0 in forum PollsReplies: 23Last Post: 6th Apr 2011, 05:31 -
What's the name a program? unkown program
By Andrey81 in forum SubtitleReplies: 1Last Post: 26th Jan 2011, 12:04 -
How to backup email's
By tcory in forum ComputerReplies: 11Last Post: 1st Jan 2011, 09:40 -
Best backup program
By Cracktower in forum Video ConversionReplies: 6Last Post: 6th Nov 2010, 09:11 -
MKV to AVI program, hardsubbing program, adding subtitle to DVD Flick
By projecttemp in forum Video ConversionReplies: 1Last Post: 21st Sep 2009, 08:42
