  1. alright, well i have a dvd recorder and i just figured out how to get my videos off of my finalized disk onto my computer, i use the dvd ripping software called "aoa dvd ripper", and well i found out that the disk has to be finalized to get it on the computer, and i was whondering if there was a different way to go about this so i didnt have to waste a whole 30 min disk on one 5 minute video, and so i dont have to finalize the disk. any help would be really appreciated. thanks
    Apr 2004
    Miskatonic U
    Use DVD RW discs instead
    Read my blog here.
  3. do you have to finalize them to copy them over??
  4. Member ricoman's Avatar
    Jun 2004
    CT, USA
    You have to finalize it for any other machine to be able to read it. Once you're done, just reformat and rewrite.
    I love children, girl children... about 16-40
    W.C. Fields
  5. how do you do that?
  6. and its also for a camcorder, it takes those small discs, the handycam ones
    Apr 2004
    Miskatonic U
    http://www.verbatim-europe.co.uk/en_1/product_dvd-rw-8cm-matt-silver_58.html
    You might also try changing the subject of the thread to something more meaningful and accurate. If you think you have a big problem now, you have no idea what you are in for.
    Read my blog here.
  8. DVD+RW doesn't have to be finalized. DVD-RW does.
