  1. I am new here :)
    Mar 2010
    Germany
    Hi folks,
    I give up... After 2 days of trying and testing I need to ask here.
    I am desperately looking for the correct parameters. I want to edit the output in Final Cut Pro.
    The compression can either be MPEG4 or H.264. Awesome would be Apple ProRes, but I don't have this patch installed.
    I did have some sort of success but for each result I got, FCP wanted to render. Either the video track or the audio track. And YES, I let FCP adjust the sequence settings to the video file ("The sequence settings differ from the footage want to adjust? YES!").
    How do I get files that I can use in FCP w/o any need to render it in FCP??
    thank you so much,
    masa
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by masaeurope View Post
    Hi folks,
    thank you so much,
    masa
    Not much info provided. FCP uses the AIC or ProRes422 for these formats.
    http://www.kiva.org/about
  3. I am new here :)
    Mar 2010
    Germany
    What info do you miss? I'll provide them.
  4. Member edDV's Avatar
    Mar 2004
    What is your source format?
    What is your project setting?
    Wanted to render what?
    "How do I get files that I can use in FCP w/o any need to render it in FCP??"
    You match project format to source format. For FCP that would be DV or uncompressed unless you first convert to a digital intermediate (AIC or ProRes422).
  5. I am new here :)
    Mar 2010
    Germany
    edDV thank you for your help.
    Well, my source format is flash (flv). I need to convert flv to [FCP-compatible format]. Not a rethoric, but simple question, I'm learning (!): Does that matter?
    Output-Format should be a .mov, H.264 or MPEG4, size = source, high-quality (no or few quality-loss, close to the original as much as possible), audio should be stereo in same quality as source. I did try several dozens of setttings. This one comes pretty close to what I need:
    ffmpeg -i ./source/input_file.flv -vcodec libx264 -vpre hq -s 800x450  -ar 44100 -ab 256k ./results/output_file.mov
    Even though I adjusted the sequence settings to the output-file FCP still wants to render the clip (red line for video track).
  6. Member edDV's Avatar
    Mar 2004
    You get the red line for any non-supported video format. flv isn't directly supported.
    I don't know how to deal with non-standard resolutions in FCP. Premiere Pro is avaialble for OSX and can support arbitrary frame sizes but you would still need to decompress flv to RGB or YCbCr.
  7. I am new here :)
    Mar 2010
    Germany
    ?!?! Yes, that's why I am using ffmpeg, in order to convert it into a standard video format. ?!
    "standard" for FCP is AIC (Apple Intermediate codec). It makes huge files so make sure you have plenty of HD space. Once you're done editing you can transcode it into a delivery format (like H264/MP4).
