  1. I have some 16/9 video captured from the TV at 1440x1080. I want to rencode to x264 and HDconverttoX doesn't want to know. Megui works fine, but it won't let me resize to 1920x1080 which is the 'stretched' size. It keeps reverting back and if i edit the avs script myself it won't encode at all. It's happy to resize to say 1280x720. Anyone know how i can resize to 1920x1080 please?
  2. what do you mean it won't encode at all if you edit it?
    make your own .avs script. maybe there is a bug with the script generator
  3. I'm not too au fait with creating scripts. So i took the avs that megui created from the dga file i made (it couldn't open the .ts file directly)
    thus
    Import("F:\Genericdga.avs")
    #deinterlace
    #crop
    LanczosResize(1440,1080) # Lanczos (Sharp)
    #denoise
    and changed it to
    #deinterlace
    #crop
    LanczosResize(1920,1080) # Lanczos (Sharp)
    #denoise
    and b****r me - I retraced my steps to report exactly what happened - now it seems to be working fine. Perhaps i mistyped something when i did it last time. Sorry!
  4. The efficient way to encode such a video would be encoding at 1440x1080 (no resizing at all) and using a flag to make it display at 16:9 (i.e. anamorphic encoding). That's probably what MeGUI was trying to do.
    Resizing to 1920x1080 is just a big waste of bits.
  5. Well, that depends on what SAP you're using. I use a wdtv and anamorphic encoding is a PITA.
  6. Originally Posted by Bully9 View Post
    From a brief googling it looks like there was a bug with anamorphic MKVs on the old WD TV, but it was fixed some time ago. (Even then, there was no problem with anamorphic MP4s.) Which version is yours?
    I'd be quite shocked if the WD TV Live couldn't handle anamorphic encodes...that would be pretty laughable, and sink the device.
  7. Any HDMI connection to my TV disables my screen sizing functions. I've always ripped avis to actual size and i think that's the safest solution. Employed on 90+ % of all the mkv/avis "out there" so i guess it can't be such a bad idea Appreciate your input.
  8. Originally Posted by Bully9 View Post
    The "actual size" is 1440x1080, and the "display aspect ratio" is 16:9.
    AVIs are ripped to square pixels for compatibility purposes, because AVI is an ancient container format. MKV and MP4, on the other hand, are modern containers built to offer proper anamorphic display, so there's no reason to resize when encoding to those. It's a bad idea quality-wise, but I gather all the encoders out there don't really care about that.
    edit: Since you're just encoding for yourself I guess wasting bits doesn't matter to you. In that case, see if clever anamorphic encoding is enabled in MeGUI and disable it. Then you'll be able to resize to whatever you want, I think.
