Hi, Beeing new to DVD authoring I want to know if there is a authoring software (PC or Mac) where I can place ac3 and pcm audio files in the same project.
My idea is that the end user will select, at the initial menu, 5.1 (ac3) at 48/16 bit or a PCM 96/24 bit stereo wave file for the exact same video program.
Sony Vegas, Corel Video Studio, Adobe Encore are possible candidates but I can't find this particular information on their web sites.
Tks for your reply
All the Best
Joannes
dvdlab pro authoring supports dual audio tracks. it will warn you 24 bit audio is not dvd spec, but will let you use it anyway.
Tks for your reply. I will check your recomendation. My goal is to avoid the need of releasing SACD or DVDA as in my country we don't have that many players.
Instead a DVD with "no video" or a fixed image and just 5.1 or stereo 96/24 audio might be a solution for audiophile type release.
I will keep you posted on my attempts
All the best
J
MKV files with Audio in DTS need to convert audio to AC3
By THEHNIC in forum AudioReplies: 5Last Post: 3rd Jun 2011, 09:17 -
Opening .ac3 audio files in Sony Vegas?
By Thunderhead2772 in forum EditingReplies: 1Last Post: 18th Jul 2010, 21:55 -
editing dvd/bluray audio files, dts-hd and ac3
By krohm in forum EditingReplies: 7Last Post: 9th May 2010, 09:31 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 15:45 -
How can I extract AC3 audio from VOB files?
By Sean_ve99 in forum EditingReplies: 6Last Post: 1st Oct 2007, 05:56
