I became interested in this program because of it's ability to create HD-DVD's on DVD5 and DVD9 DVDr's. It does produce files that will play on my HD-DVD player,HD-A20 and HD-A3 with 4.0 firmware. It's nice to be able to back-up new BR movies to play on my HD-DVD players. The program does work but I'm having two problems.
1.) according to the authors website it uses 3xDVD to create HD-DVD's. The file structure it creates is very different than a normal HD-DVD. I notice when playing on my players if you interupt linear play for any reason or even enter setup the player will lock up in 2-3 minutes after resuming play and I have to unplug the power cable to restore player operation.
2.) I can't get chapter stops to work.
Are these typical for this program?
Yes, chapters are not supported. I don't know about the other problem but basically multiAVCHD creates 'standard/simple' HD-DVD output, not ADVANCED as you noticed the difference already.
Laugh and the world will laugh with you. Cry and you will be alone
Multiple AVIs to a single SD-DVD with MultiAVCHD
By jeffdb27 in forum Authoring (DVD)Replies: 3Last Post: 1st Jun 2012, 16:17 -
Dvd to Blu-ray multiAVCHD
By Marco33 in forum Authoring (Blu-ray)Replies: 5Last Post: 26th Jan 2012, 12:34 -
Creating the DVD after using multiAVCHD
By CubanoLibre in forum Authoring (DVD)Replies: 4Last Post: 12th Jul 2011, 09:39 -
Need help by authoring/Burning AVCHD DVD (multiAVCHD/ imgBurn)
By benji179 in forum Newbie / General discussionsReplies: 0Last Post: 4th Apr 2010, 18:20 -
m2ts files on DVD with MultiAvchd
By besthost in forum Authoring (Blu-ray)Replies: 2Last Post: 3rd Jul 2009, 05:06
