Hello all,
I'm new to these conversion stuffs. I downloaded a video of .mp4 format. Unfortunately i had a 1000ms out of sync audio. Then i found that Avi-Mux can fix the out of sync audio. So i downloaded AVI-Mux_GUI-1.17.8 and i tried to load the file in it but i found that .mp4 is not supported.
Then i found that AviDeMux can convert the video to .avi. So i loaded avidemux_2.5.2_full_win32 and tried to load the file. I got the following warning.
Confirmation
H.264 detected - If the file is using B-frames as reference it can lead to a crash or stuttering.<br>Avidemux can use another mode which is safe but YOU WILL LOSE FRAME ACCURACY.<br>Do you want to use that mode?
When i proceed with it i got a .avi file but it was unplayable (tried Media Player Classic (KM Codec lite), VLC Player and KM Player).
Then i found that x264 library can be added with AVIDeMux by reading the article here - http://www.avidemux.org/admWiki/index.php?title=H264.
But i dono how to proceed?
How can i get the audio fixed for my video without losing the quality and increasing the size (700 MB) ?
Thank you all.
Regards
NLV
	Okie i ignored it (gave NO) and i gave 1000 ms in the audio shift. But its not working. As the video progresses the audio is going out of sync more and more.
 But in VLC player i used Ctrl + K to shift the audio to +1000ms and i watched the whole video fine. What could be the problem with AVIDeMux?
 Thank you.
 Regards
 NLV
  Shifting audio for MP4 not working with avidemuxBy markbc in forum Newbie / General discussionsReplies: 8Last Post: 20th Feb 2012, 00:15
  Avidemux .. editing AVI h264By rogerer in forum EditingReplies: 2Last Post: 3rd Nov 2011, 12:43
  MOV format from video camera>avidemux>mp4 out of syncBy duhmez in forum Video ConversionReplies: 2Last Post: 7th Apr 2011, 21:36
  Audio/video out of sync after converting (avi to mp4)By Foxy Gogo in forum Video ConversionReplies: 1Last Post: 10th May 2010, 13:13
  Avidemux - best quality from wmv to avi/MP4/H264?By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 20th Dec 2009, 05:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
