I have some good HD videos in my PC , burned to a DVD and tried to watch in my PS3 and nothing, it wont read it.
Results 1 to 10 of 10
You'll have to be a little more specific than that.
Did you create a DVD-Video disc? If so, how did you create it, and with what software? What are your source files?
If you created a data DVD, with video files on it, what source files did you use? Did you try hitting Triangle to view all the files on the disc?
The PS3 doesn't recognize all video container types (for example, .MKV) - and is picky about the ones it does recognize, so if the videos are encoded in a way it doesn't like, it'll refuse to play them (the file browser will claim they're 'Unsupported Data').If cameras add ten pounds, why would people want to eat them? -
I just used the default windos Vista burner that came with the laptop I used.
I have no experience at all really.
When I tried to play it in the PS3 it said Data disc, I double click and said contains no data. Went to my other PC and it played the video no problem.
How should I do this? -
Use a different burner than Windows' built-in routines to create a data disc. Personally, I'd recommend Imgburn.
Aside from that, however, you still haven't mentioned what types of files you're attempting to get the PS3 to see. I'm running from memory here (since I haven't had to do this on the PS3 in a while), but if the disc shows up in the PS3 file browser but the files don't, highlight the disc, press Triangle, and select the option that shows all the files. If there are files on the disc the PS3 doesn't like, it should list them as 'Unsupported Data.'
PCs are far less picky about videos than standalones like the PS3.If cameras add ten pounds, why would people want to eat them? -
I get the Unsupported Data message in PS3 pressed triangle and says there is no data and reads 0 KB
...So... what kind of files are you attempting to play in the PS3? .MKV? .MP4? .AVI?
PS3 doesn't play MOV files. You have to convert them to something the PS3 can read. You can convert them to a DVD structure with AVStoDVD or DVD Flick or ConvertXtoDVD, or you can try converting them to Divx/Xvid encoded AVI, or AVC encoded MP4
Read my blog here.
Just in time , I was just going to ruin another DVD.
Thanks for the help.
Hope I can make it work -
Reading the owners manual would have told you what formats the PS3 will play,
or you could have done this....
http://lmgtfy.com/?q=what+video+formats+will+the+PS3+play
Can I use my PS2 controller on my PS3 to play PS3 games?
By jbitakis in forum Newbie / General discussionsReplies: 3Last Post: 13th Dec 2011, 14:24 -
UK DVD's played in US
By jack209 in forum Newbie / General discussionsReplies: 11Last Post: 24th Oct 2009, 16:34 -
burned DVD can't be played
By linda.0p in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 13:18 -
PS3 Video 9 - .AVI to PS3 - Settings
By dec60228 in forum Video ConversionReplies: 0Last Post: 22nd Feb 2008, 13:48 -
Dvd jumps when played
By Radox The Green in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 13:56
