Sound Problem, i have my desktop w/ Creative CT4670 Card connected to my stereo receiver. this receiver has no bass / treble controls and so the sound has far too much bass. is there any kind of mixer software that would help with this ?
The software that came with the card (SB Live?) should have a mixer. If not, check the player software. I know that most, including VLC, have built-in equalizers.
I got the Ct4670 card from another PC -no software with it. i was able to find a driver but not much else.
Whatever you are using to play your media files should have an EQ. Like I said, try VLC.
Not all cards have EQ abilities.
The drivers from the kx-project should solve your problem.
Also, there are at least two free DirectShow filters for audio post-processing. -
I have an older PC as (mostly) a server, and that specific cards does (SB Live basic/value). When I installed XP on it with basic drivers, the EQ worked fine in VLC.
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 13:02 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 16:13 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 21:05 -
Too high treble
By Jelleke in forum RestorationReplies: 6Last Post: 13th Sep 2007, 14:02 -
ADVC-300 audio capturing oddities (treble/bass response)
By Wile_E in forum Capturing and VCRReplies: 2Last Post: 12th Sep 2007, 06:48
