hi.
i tried reading some posts but i cant find any answers...
i have a h264 file (i rename it to 264) , use avc2avi , enter the fps value , and the final avi file is like corrupted. windows media player wont play it, vlc displays an error message "file is broken" ... i tried to repair it with vlc, but this is temporal, and... the avi file seems to have frame problems, its no smooth like the original one...
any ideas to fix this problem?
thanks!
	where was the file from originally?
 I would put it in .mkv or .mp4 container, because b-frames can cause corrupted playback and sync issues in .avi container
	the original is a mkv... avc and dts
 i did this:
 1. convert with popcorn the dts to ac3 (cant use it in my dvd player althout it can play dts...) with ac3 the movies work also.
 2. Mkvextract GUI to extract the h264.
 3. rename the h264 to 264 for avc2avi...
 strange . i did this once a few weeks ago and it worked ok...
  Fix bad avi fileBy TBoneit in forum Video ConversionReplies: 8Last Post: 4th Oct 2011, 12:17
  to avc2avi gui creator bad avi filesBy xxx99 in forum Video ConversionReplies: 0Last Post: 26th Oct 2010, 12:05
  any program like avc2avi?By userpc in forum Video ConversionReplies: 3Last Post: 5th Oct 2010, 13:28
  .avi file cannot be repaired - need to remove bad/corrupt framesBy realtechtalk in forum Video ConversionReplies: 0Last Post: 7th Sep 2008, 13:27
  Fix Bad Header/Bugs in an .avi divx fileBy krisbee in forum LinuxReplies: 3Last Post: 24th Sep 2007, 08:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
