Hi, I am using Adobe Audition's Noise Reduction feature to try remove some very distracting noise from my audio files, but I am having problems completely removing all the noise without degrading the primary sound. I attached a clip of the hiss/noise I am trying to remove. The first part of the clip is the original noise, the second part of the clip has some of the noise removed via Noise Reduction in Audition and the third part of the clip was applied the Noise Reduction again. There is a gurgling sound (for a lack of a better word) after applying the Noise Reduction, but the more you capture a piece of the noise and apply it to the clip the more it downgrades the audio I want to preserve. Can this noise be removed? I have also tried using Sony's Sound Forge, Audacity, and even Magix Audio Cleaning Lab, but I get the same results. I would appreciate any feedback. Thank you.
What is the "primary sound" in that clip? or the stuff you want to keep? All I hear is noise. Is there some hidden easter egg or something like "where's waldo ?"
This is the noise only. The primary sound is talking. I only included the original noise, and the Noise Reduction processed twice. The point of clip is display the "gurgling" noise after processing the Noise Reduction to the first part of the clip. I hope this makes sense.
You need a sample with noise and the stuff you want to keep to distinguish the frequencies that you want to keep vs. discard.
Otherwise I could process it and it would be silence. (I did, and it was "perfect"... i.e. all the noise was gone)
NR *always* degrades the audio. The more frequencies that overlap between the wanted parts and unwanted parts, the more distortions you are going to get
I hope that makes sense -
I can fix that -- not a problem.
But I don't work off noise prints, I need a sample file with audio, to see if damage is being done to the left frequencies.Want my help? Ask here! (not via PM!)
Yes, that does make sense. I appreciate the response and the input. How would you suggest go about fixing this with as little degrading as possible?
I'm relieved to hear that it can be fixed, but I would like to learn how to do it myself if that is possible. I have many files with that kind of noise and I will need learn how to process those and clean those up myself. I would appreciate any suggestions you have to offer and I appreciate you taking the time to help me out. Thank you. -
You still need to share a sample that can be fixed before anyone can say "yes, this fixes it"!
Without even downloading it, I'd suggest Sony / Sonic Foundry NR-2 as a decent denoiser - better than Audition's. There are several others.
Cheers,
David.
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 19:42 -
How do you get rid of hissing air noise from digital camera video
By johnharlin in forum AudioReplies: 1Last Post: 22nd Sep 2010, 23:24 -
Getting rid of crackling noise
By adamf154 in forum AudioReplies: 1Last Post: 14th May 2010, 07:40 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 00:57 -
getting rid of vista
By sue1951 in forum ComputerReplies: 12Last Post: 6th Aug 2007, 21:53
