Results 1 to 9 of 9
  1. All,
    In need of an ISO tool that will allow me to open a problem DVD ISO and extract the contents so that it can be burned.
    THX, JNT
    For the love of God, use hub/core labels on your Recordable Discs!
    Tried isobuster? the free version may be enough.
  3. IsoBuster, I've used it with success. It's a bit complicated to use, but powerful. Go to the website and read the manual. Also, IsoPuzzle has been recommended by members here.
    Good luck.
    [EDIT] Beat me again.
    Pull! Bang! Darn!
  4. I tried ISObuster and it can see the folders in the ISO file; BUT I have to pay to extract.
    Will try IsoPuzzle tonight.
    THX, JNT
  5. Well, ISOPuzzle did not work, nor did MagicISO.
    Downloaded the trail version of PowerISO and it did the trick!
  6. DECEASED
    Jun 2009
    Heaven
    Can't 7-zip open .ISO archives ???
  7. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    If you have access to a version of Alcohol 120% it may do the trick. Worth a try
  8. Member usta's Avatar
    Jun 2009
    Netherlands
    Yes it can. Also WinRAR can do that.
  9. Gamer and Builder HotDamn!'s Avatar
    Nov 2009
    I use WinRAR. My Uncle sent it to me through an IM and it works great.
