Kay, so I wouldn't say I'm a newbie at all, but considering I AM new to this forum I'll post here. Basically It could be put in either the Editing or Authoring thread cause its kinda both.
Basically I'm wanting to be able to import a .vob file originally from a dvd, edit the sound from it, and save it back as a .vob file. I know there is no direct way of doing this, but anyone have any other way of doing it?
Adobe Premiere Pro let me import and edit, but I can only extract as .avi, etc.
Thanks!!!!
	1. Demux the VOB. Open the VOB in DGIndex and File->Save Project and Demux Video. That will give you the M2V video and the AC3 audio. At the same time you can decode that AC3 audio to WAV audio, if you wish. The included help file explains how to do that.
 2. Edit the audio. I don't know what you want to do or how you plan on doing it. Many audio editors will want to import WAV audio.
 3. Remux (perhaps after reencoding the audio to AC3). To DVD with Muxman. To MPEG or VOB using Imago MPEG Muxer.Last edited by manono; 8th Mar 2010 at 11:44.
	Awesome. I read something else about that, but it confused the heck out of me so I didn't know.
 Great job explaining
 So I'll try that! Thanks!
  IVTC a vob/m2v file before FCP editingBy kmxe in forum MacReplies: 18Last Post: 18th Mar 2010, 03:15
  editing a vob fileBy salazaree in forum EditingReplies: 1Last Post: 13th Nov 2008, 03:41
  Editing a VOB fileBy AbePagota in forum Newbie / General discussionsReplies: 3Last Post: 19th Oct 2008, 03:19
  making/editing clips from a vob fileBy ramlin in forum EditingReplies: 2Last Post: 25th Jun 2008, 06:46
  Editing VOB FIle HELPBy abdulla123 in forum EditingReplies: 4Last Post: 16th May 2008, 18:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
