Hello All
a bit of an odd one.
Have been using Handbrake for converting a few of my movies to iPod format (m4v format)
A couple of the movies have forced subtitles in them. Handbrake handles these fine, although the subtitles had to be added from an external file (SRT file). Because of this Handbrake cannot burn in the subtitles.
When you play back the m4v file in either Quicktime or on the iPod itself you have to manually turn on the subtitles.
Question - is there any way to set a flag in the actual m4v file so that it always plays the subtitle track in the m4v file? I know that on my iPod I can select to always play subtitles, but I have some purchased iTunes movies, and it would mean that the ordinary subtitles on these movies would play (I don't want to have to keep turning that option on and off) It would be better if the player (Quicktime) just knew that there was a subtitle track in the movie and played that one by default.
Any suggestions?
Thanks.
Adding soft subs with mkvmergeGUI for mpclassic
By chibaking in forum SubtitleReplies: 13Last Post: 29th Jun 2011, 15:46 -
Hardsubs to Soft Subs & Other Questions
By Startropic1 in forum SubtitleReplies: 2Last Post: 12th Apr 2010, 13:30 -
Backup DVD to mkv with soft subs
By rapaz in forum DVD RippingReplies: 28Last Post: 24th Dec 2009, 00:16 -
How to convert MKV with soft subs to AVI using DVDFab 6.x
By Shilar in forum User guidesReplies: 0Last Post: 28th Aug 2009, 10:15 -
How do I put soft subs into my iPod h.264 MP4 files?
By FallenAngelII in forum SubtitleReplies: 1Last Post: 4th Nov 2008, 16:31
