Hello members. I have a question about encoding. I'm trying to better the quality of the resolution some VOB files. I would like to have it as high in quality as possible with loosing anything. I was wondering what steps I must make and want software is best to use to do this? Looking for a good encoder software if that's what it is that I need. Looking for some suggestions. I've provided what the video file specs are that I want to enhance using MediaInfo. Thanks for any help here.
LegendaryGamer
This is the quality of the VOB below
Format : MPEG-PS
File size : 397 MiB
Duration : 22mn 29s
Overall bit rate : 2 467 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Duration : 22mn 29s
Bit rate mode : Variable
Bit rate : 2 113 Kbps
Nominal bit rate : 9 800 Kbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Standard : NTSC
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.204
Stream size : 340 MiB (86%)
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Duration : 22mn 29s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 20.6 MiB (5%)
Audio #2
Format : AC-3
Duration : 22mn 29s
Bit rate : 128 Kbps
Text #1
Format : RLE
Format/Info : Run-length encoding
Text #2
Format : RLE
Text #3
Format : RLE
If that's the source, I doubt you can improve much on it. If it's the source, a small sample might help us to see what can be done. If that's reencoded from the source, then give it a higher bitrate - a much higher bitrate.
Do you know what 'resolution' is? The DVD specs define the resolution, in this case 720x480.I'm trying to better the quality of the resolution some VOB files
Is English not your first language? -
post a video sample
Change VOB Resolution
By Simmons in forum Video ConversionReplies: 4Last Post: 30th Aug 2011, 08:37 -
Can I get VOB to smaller file size with no loss of quality?
By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 14:11 -
Converting a dvd vob to a high quality compressed file.. for youtube.
By powrtoch in forum Video ConversionReplies: 3Last Post: 28th Nov 2009, 05:24 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 14:38 -
Cutting VOB File without any quality loss? (ending credits)
By willhenderson in forum Newbie / General discussionsReplies: 10Last Post: 15th Oct 2008, 23:45
