I store my DVD-Rs in two-sided (4 hole) black plastic refill sleeves and then in boxes. I had been purchasing these sleeves from meritline but they recently changed the sleeves from a taller, thicker/sturdier sleeve that had a tab that helped keep the DVDs in place to a smaller, thinner sleeve that is very tight when 2 DVDs are placed in a sleeve. In short, the sleeves are more cheaply made and I worry about the tight fit scratching the DVDs. Supermediastore advertises the sleeves I used to buy but when I ordered the sleeves, they were the same as the new sleeves at meritline. Does anyone know where I can find the sleeves that are pictured in the Supermidastore link? Thanks.
All sleeves scratch --- know that some scratches cannot be seen by your eyes, but will still hinder the laser.
Thread moved to media where you can get better answers.
Are plastic sleeves good for DVds?
By cynikalhedonist in forum MediaReplies: 10Last Post: 28th Feb 2011, 01:12 -
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 20:39 -
canada switching to plastic money
By deadrats in forum Off topicReplies: 5Last Post: 11th Mar 2010, 16:49 -
any sleeves better than tyvek?
By spiffy in forum MediaReplies: 3Last Post: 20th Aug 2007, 12:15 -
Create your own cardboard or plastic DVD slip cases?
By lordsmurf in forum MediaReplies: 3Last Post: 23rd Jun 2007, 17:31
