    Dec 2006
    Peru
    When I converted 3 files (flv) to dvd using convertxtodvd the first video is always out of sync and all the videos (2nd and 3rd..) are ok,like the software is trying to sync after 20 min; this hasnt happened to me before with this tool, Could be this happening because i removed some codecs? What should i do? ..convertxtodvd is suppossed to be the easiest tool with no hassles
    thanks
    Apr 2004
    Miskatonic U
    No solution can be guaranteed to work all the time, especially with flaky formats like FLV. Try using something like any video converter to convert the flv files to DVD compliant mpeg-2 and see if they remain in sync. If so, you can author these files instead.
    Read my blog here.
