    Mar 2008
    I have been burning avi files, in folders, to DVD for 11 months. Hitting the play button on my Toshiba SD-185EKB DVD player would open the folders and list the avis ready to play. Suddenly the play button no longer opens the folders. I can burn the files, without folders, and there's no problem, but I cannot access all my previous stuff.
    Can anyone help?
    Thanks in advance.
  2. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Are you burning the files to DVD-RW? RW discs do tend to degrade, over multiple uses.
    Can you access the files without any problems on your computer?
    Mar 2008
    Burning to DVD-R
    No problems with disks on my PC
  4. Did you update the firmware recently? Sometimes manufacturers remove functions.
    Do folders still work on a CD-R?
    Mar 2008
    No updates. Never used CD-Rs
