Hey guys seem to having a problem with sending email to hotmail account using outlook 2007, when sending a mail I get an undelivered message in my inbox saying:
Your message did not reach some or all of the intended recipients.
Subject: **********
Sent: 07/03/2010 20:51
The following recipient(s) cannot be reached:
'***********@hotmail.com' on 07/03/2010 20:51
550 Recipient Rejected: Relay not allowed
This seems to only happen when sending to hotmail accounts, any suggestions how I can fix it?
I ran into the same problem, but using a different email client, Pocomail. In my case it was because I used a different ISP than my email server was on to try to send mail. Maybe not your problem, but the same errors. Basically, you aren't getting onto your email server for sending. That's the 'relay not allowed' error. You don't have permissions to use their server for sending mail. I did try Outlook, got the same error. I switched back to the correct ISP and the client works fine now.
If that isn't it, check that your password is correct, along with your email address and other settings. Not likely to have changed by themselves, and if it worked before, it could be your email server is blocking Hotmail. I suspect sending to Yahoo mail or others will have the same problem, though. If you have more than one email account on your ISP email server, the email to that would likely work.
And you might check this from MS: http://office.microsoft.com/en-us/outlook/HA011128331033.aspx -
I had a look at my mail account settings in outlook (tools, account settings) and double clicked on the only account I have, then chose the 'more settings' option. I then went to the outgoing server tab and clicked the 'My outgoing server requires authentication' box and just chose the option use the same setting as the incoming server. This appears to have done the job as I have not had an undelivered message yet!
Sounds good.
Glad it was something simple.
In my case I have to use the alternate ISP if I want to send email from my laptop. A bit of a pain because it's much slower than my main ISP and I have to switch ISPs in my Network and Sharing Center. But my main ISP doesn't have a email server and I don't use webmail.
One nice thing about a dedicated email client over webmail is I have all my emails, incoming and outgoing since 2003, archived.
Outlook not sending email with attachments
By Squid_uk in forum ComputerReplies: 25Last Post: 12th Oct 2013, 03:09 -
Phishing Emails
By DuBsTaR in forum ComputerReplies: 4Last Post: 15th Oct 2008, 10:08 -
Where do emails and bookmarks live in XP?
By GMaq in forum ComputerReplies: 3Last Post: 10th Feb 2008, 12:42 -
Multiple emails address??
By Seasonal in forum Off topicReplies: 4Last Post: 20th Dec 2007, 12:05 -
Not getting post reply emails. --SOLVED--
By freebird73717 in forum FeedbackReplies: 3Last Post: 13th Sep 2007, 11:27
