Which program do I use to create high quality .mkv from DVD?
preferably one that does not need .net framework to run.
How long does it usually take to create .mkv from DVD on a new computer?
Thanks very much.
It depends on what you want as an output. If you want the highest quality possible, just demux the video and audio from the DVD, then mux them into a mkv container. No quality loss. Tools required - DGIndex, MKVToolNix.
Read my blog here.
How to easily convert DVD to high quality MP4/MKV H264 using free tools
By Baldrick in forum User guidesReplies: 45Last Post: 25th Jul 2017, 23:35 -
[Q] Convert MKV Format Profile from High@L5.0 to High@L3.1?
By xIntenso in forum Video ConversionReplies: 5Last Post: 26th Aug 2013, 22:46 -
Which is better, AVIDEMUX or HANDBRAKE to convert high quality mkv's to mp4
By rxloren in forum Newbie / General discussionsReplies: 8Last Post: 1st Nov 2010, 21:33 -
Convert MKV to AVI/MPEG-2 High Quality file for HD author
By ronorkis in forum Video ConversionReplies: 7Last Post: 1st Nov 2010, 09:23 -
How to encode High Quality MKV to (SD) AVI?
By whatever911 in forum Video ConversionReplies: 13Last Post: 4th Dec 2008, 23:46
